2007 gt 500
Ford racing 2.3 upgrade 15 psi boost
SCT tuner
Hpipe no cats
Stock mufflers
67mm throttle body
Dynotune MP did all the work.
649 hp 606 tq pump gas
now, I'd suggest not bouncing off the limiter - the PM rods and PM gears in the oil pump are failure prone at this level. Seen a #5 rod snap. Piston wedged in the bore and the rod tore the pin out of it punching holes in both sides of the block as well as cracking it.
