1 - 1 of 1 Posts
These parts are all leftover from a build I'd done converting a 98 3.8L over to a 94 Supercoupe motor. All parts are for the 1998 3.8L.
Prices are not including shipping, but are 100% negotiable, especially if you want to combine some stuff. Please PM to make an offer. Located near Tinley Park, IL - can do local pickup if preferred
Valve Covers - $20
Coolant reservoir - $10
Motor mounts - $10
Power steering / alternator engine bracket - $20
Tensioner engine bracket - $15
Air intake - $10
Oil cooler - $10
Belt tensioner - $5
Crank pulley - $10
Power steering pulley - $5
Throttle body - $10
Upper/lower radiator hoses - $5
Fuel pump - $10
Alternator pulley - $5
Throttle cable - $5
Pcv valve/hose - $5
Water pump coolant heater hose - $5
Ac line - $5
Purge valve canister and line - $5
Egr pressure sensor - $5
Therm housing - $5
Oil pan - $20
BBK cold air intake w/ K&N filter - $40
1 - 1 of 1 Posts
