Should work no problem but you should always check the clearance.I want to put a set of AFR 185cc renegade heads on my truck. Those heads have 2.02 valve. I’m going to leave the stock cam but change to 1.7 rockers. Will that valve work with my pistons?
Agreed! Should be fine but better safe than sorry....Should work no problem but you should always check the clearance.
