I am in the process of purchasing an 89 lx hatch, and want to use my 95 Cobra R wheels that are currently on my 94gt. If I upgrade the front rotors to 5-lug and swap to some 5-lug axles in the rear, can I use these wheels? I remember hearing somewhere that the backspacing could be a problem...any thoughts?
Thanks,
Trent
You can get the lincoln mark 7 front roters, and two ranger driverside axles. All of them are from junkyard, I spend less then 200 bucks. not problem at all, made sure you have the 24mm backspace corba R.
They fit I use them on my '93. I needed to grind down the driver sider rear fender lip. The fronts rub at full lock. You don't want tire larger than 255/40 on the front, or you'll need to do some fender work. I did the conversion the high price way (Baer brakes $1800 and new FRPP 5-lug axle kit $200).
