Hello i just had a lightning 93 converted to mass air,it has headers a 75mm throttle body 1.7 rockers and electric fan, i put a c&l 76mm mass air sensor on it with 19lb tube reset the comp and it will run perfect for about 1 minite then it run rough reset it again same thing,:salute::salute: does anyone know whats wrong or should i just get a pro m checked tps and voltage to the sensor but when it runs rough if i pull the stock sensor off the c&l it will level out anyone? thanks
Hi i also converted my 93 5.0L XLT f150 truck, same as the 351 lightning but different suspention and liters lol ......., 73 mm maf is the perfect match but 75 or 76 will work just fine also but first off to resolve ur issues is what kind of harness did u use to convert to mass air flow???? ,.......one problem could be, do u have the map vacume line unpluged completly and vacume line plugged off and u say u unplug the sensor and it straitens out ??? i would say try a different maf sensor i have a 95 mustang maf sensor thats 73mm on the truck never had any problems ,i heard my ford buddies say , the maf sensor make a big difference if u have the sensors crossed between 19 and 24 lb injectors ,so if im correct the gen 1 lightnings was to have 24lb factory injectors ... need more info on what exacly what u done to help u get running but after that i highly reconmend tunning ur computer to compensate for the trucks work load if u dont ur looking into over heating problems from lean fuel to air mixers........
when i first converted my truck i got the aftermarket truck harness that blends with ur existing harness,i only had to switch 4 wires and remove 6 wires and plugged in 10 new wires from the new harness also making it a sfi system witch is very effictent btw new cams and combos love the sfi systems and easy to tune ... back to what i was saying after that u just unplug ur old injector plugs and plug in the new injector plugs and cut into driver side exaust for the second o2 sensor needed...... i used a cumputer from a 89 mustang that was sfi injected and it also works with my AOD trans when i did all that i put an E303 cam in at the same time everything was stock other than new harness and cam used same 19lb injectors well i used all the factory correct sensor and silinods was fun for awhile after tunning, it put down 165hp running very lean before tunning and after tuning it, it put down 223hp, thats y i say have it tunned highly reconmended if u want to keep ur engine running correctly...., now my new set up is a 331 stroker with a comps cams 286,300 duration 579,579 lift, last tune dynoed at 436 hp tons of fun have it as a sleeper truck ,nobody ever thought of getting beet by and old stock looking truck lol
