1986-93 8.8" axle assembly for sale. 3.55:1 gears, 31 spline Fox length axles, 3" Moroso studs, Torsen T2R differential, 12" Baer rear brakes with 40.5mm PBR calipers, braided SS hoses, parking brake cables for 1979-92 Fox Mustang. Several sets of pads. Bearing surfaces on axles are perfect. Less than 0.010" of endplay on both axles. Housing is nearly perfectly straight. Less than 0.1 degrees of toe and camber. Has not been ruined by welding on the axle tubes. Quad shock brackets have been half cut off. UCA bushings are trashed. I can remove these or install new ones if you supply them.
$1,100 for everything. Price reduced $300 if you want the axle assembly without any of the brake parts.
Located in Martinez, CA.
Photos are at link below.
