18x9.5 Y2K R's with 275's on a 5-lug '93 coupe?
Will these wheels and tires fit without too many problems on a '93 coupe (4 cyl) with '94 or '95 front spindles and a '94 or up rear? I am assuming the back would be OK, but what about the front?
The OD of these tires is very close to a 245/45/17, which I know should fit OK, but will the 30mm width increase cause a problem? Thanks.
The rear you will HAVE to keep the stock track. So ranger axles and brakes off that setup.
Up front you will have a lot of rubbing on the A arms when doing parking manuevers. So trim the jack lip off and/or go tubular with some rack limiters.
